djlunatiq said:
I am putting in a alpine deck and i dont know what wires are which from the factory. I dont have the owners manual. Do i get the wires from the stock amp? or do i get the ones that lead into the h/u area? thanks for your help
Well first of all, you shouldn't just hook up an aftermarket deck to the rear stock speaker. They are actually 2 speakers each, and the woofers are only 2ohm, and each speaker in each pair expects different frequencies. You can probably still use the fronts with an aftermarket headunit.
Ok, that being said, if you are still going to do it, here is the wiring diagram:
http://www.teckkits.com/IS300/Audio/Radio.pdf
Use the wires coming out of the amp, not the ones coming out of the head unit.
