1 - 1 of 1 Posts
Hello
I have plans to swap 2JZ-GTE Non-VVTI with Transmission auto in july.
Need advice to buy the piece of engines for Replaces complete to engine.
For example, I want to do well as the photos.
My list:
2jz front main seal
2jz rear main seal
2jz serpertine belt
Oem Thermostat
Timing Belt Ider
Timing Belt Tensioner
Oem Timing Belt
Oem Water Pump
Water Pump Gasket
Oem 2jz engine gasket
Aluminum Pulley Set
Factory Valver Covers
Oem Oil Pump
Coil Pack for 2jzgte
I want know that what is needed to complete it. :suspiciou
I know more things missing, like radiator, intercooler, turbo timer, gauge, hose, suspension, fuel system, sparks in, blow off, etc. ..
I just wanted to specify the engine to make full Replaces only.:p
My purpose is that I want the 2JZ-GTE Non VVTI engine is completely stock, more healthy and more durable:)
Thanks
1 - 1 of 1 Posts
