I want to lower my IS but no one makes a camber kit for it. I've seen a lot of them and it got me wondering if the factory camber kit is adjustable? Just a thought. Thanks for any help. (also has anyone found a caber kit that i haven't found?)
hmm well yes the Is does have a limited adjustment for camber on the rear I know. If you look on the lower control arm on the inside of the car you should see the degree settings... As for what you want to get out of it I am not sure. When you lower your car you will have plenty of camber in your rear end... I lowered mine and with the camber that is there I get plentty of tire contact to the ground more than with the normal ride...
