I'm new to the board and had a question on adding an amp and sub to my IS. I've seen other posts on tapping into the front speakers, but had some questions on how to do that.
Do you tap into the lead out of the amp or before the amp. Do you make one signal go to the existing front speakers and then another signal to the amp or do you loose the fronts completely?
Any help would be greatly appreciated before I mess something up.
Thanks
AT
Thanks
AT
