Okay so I am going after the amp on the factory sub for signal. But the power off of that amp is burning the crap out of my Hi/Lo converters. I have tried 3 different types now and need to find one that is designed for the IS350 M/L sound system. dose anyone know of one?
Are you following the schematics for the ML system? You need to carefully tab into each cable and make sure you know very well which is Positive and Negative and also not to mix the Channels.
Keep in mind also that the ML system pushes more power to the Sub, so you might want to watch your Bass levels on the Head Unit. I would keep it at no more than 0 or 1 and just let your new Amp do the job.
