Hey guys,
I succesfully added a shock sensor to my stock alarm. I don't know if you are all interested, but my shock sensor has a Warn Away trigger and the Main trigger. This is how it's working right now:
- When the car is off, the doors are all closed and the alarm is armed, the sensor will be activated, and the warn away will be active along with the Main trigger.
-When the car is off, the doors are all closed, but the alarm is not armed, the sensor will be activated (after 15 sec of closing the door), and the warn away will be active, but the main trigger will not.
- When the car is off, but any of the doors are open, the sensor will not be activated.
- When the Key is in either ACC or ON position, the sensor will not be active.
The Warn Away is currently working with the car horn, not the alarm horn.
This is how I did it:
All I needed was 3 relays, two Mini Add-a-Circuit, and cables, terminal connectors and cable ties.
Schematic
Terms
If you need a better picture PM me, I can email a better one.
Try this at your own risk :roll: . Mine is working fine :D . If you have any doubts post them here.
Sorry to bring up an old post, but the links are broken on this and the PM function doesn't appear to be working.
Chaskid:
Can you fix the links, or e-mail them to me.
