1 - 2 of 2 Posts
I have a reoccurring problem with my AC. It will turn on randomly while the switch is on OFF. I play with the temperature and fan speed so I do not waste gas. AC is cold, and the problem will fix itself eventually. I’ve seen similar problems, I am going to try changing the ac compressor relay.
It could also be the (blower resister) control module. Or even the controls you are using. The pressure switch and A/C compressor clutch.
1 - 2 of 2 Posts
