My 03 Lexus is300 ac keeps going off and I don’t know what’s causing it. Everything I drive I put the Ac on low it’s okay but just when I put it up a little bit the ac blows out hot air. If you anyone knows the problem please let me know
Check your air blend servo. To make sure it is going all the way cold or hot. Next check your pressure levels.
2002 Lexus IS300
I’d check the Freon level. Since it’s cold while on low the blend door must be already in it’s proper position.
