1 - 9 of 9 Posts
what is the best timing for it?
um...
what kinda question is that.....? :-?
you shouldnt be asking this... as it is different on all cars...
timing could change the characteristics of hp/tq curve, too...
its all trial-and-error, so pay some money and let the shop do it for you.
tell us if tuning the exhaust cam is worth it...
good luck :D
i think u can feel more difference of it after f/i :chill:
Discussion Starter #7
um..
so does that i should set my HKS at -3 too? My friend is helping me to install it because he is got one of those timing guns....something like that i think.
Anyway, thanks for all the comments so far and would someone with HKS cam gears please make some posts! Thanks!
Lexus IS300 '01-'02 : The IS 300 has Variable Valve Timing which means your intake cam and valves are being constantly adjusted for maximum power. The exhaust cam and valves are not being adjusted at all. We have found that using a cam gear on the exhaust side can add up to 9 hp! It is recommended that only a skilled mechanic install and tune any cam gears due to their difficulty. The intake cam gear is not required. We have found that setting the exhaust cam gear to -4 marks on the cam gear (-8 actual degrees) will yield the most gains.
I made 10 rwhp with the cam gear but keep in mind I have force instruction!
So a car without supercharger or a turbo might only make 4 or 5 rwhp.
1 - 9 of 9 Posts
