1 - 19 of 19 Posts
Cleaning with Clay
Every car finish shares a common enemy: pollution. It relentlessly pursues your car from the second it leaves the factory until your car meets its ultimate demise. It's in the air we breathe, it's on the roads we drive, and it attaches to your car's paint, where it bonds and begins a process of oxidation.
When contaminants get a solid grip on your car's paint, washing alone may not be enough to remove them. Pre-wax cleaners also may not be able to exfoliate large particles. In this case, you have two choices: use a polishing compound, which removes a lot of paint material, or use Z-18 ClayBar. Clay isn't a polish or a compound, it is a surface preparation bar that smoothes the paint and exfoliates contaminants.
USES FOR CLAY
Clay is not a cure-all or a replacement for polishing. It's a tool for removing surface contamination. One of the many reasons for using clay is the removal of brake dust. Brake dust contamination, which attaches to painted rear bumpers and adjoining surfaces, is a metallic surface contaminant that can be removed safely and effectively by using clay.
Clay is also very effective on paint over-spray. If the over-spray is particularly heavy, you may want to seek the assistance of a professional. Tree sap and tar specks can also be safely removed with a clay bar. Recently, I have also started using clay on my windows (exterior) to remove heavy road film, bug deposits and water spots. It works very well, and seems to outperform even the best window cleaners.
EVALUATING YOUR PAINT FOR CLAY
How do you know if you need to use Z-18 ClayBar? After thoroughly hand washing and drying your car, stretch a piece of saran wrap over your hand extending past your fingertips. Gently slide the saran wrap across the finish of your vehicle. Does the surface feel bumpy or gritty? These bumps are contaminants attacking the finish of your car. Removing these surface contaminants (rail dust, road tar, bug residue, paint over-spray, brake pad dust, hard water spots, etc.) will improve both the look and health of your car's paint.
No matter how well you hand-wash your car, many of the contaminants that have worked their way into your car's paint finish will remain. Have you ever looked at your applicator pad after applying a coat of polish? What do you think that black stuff is? It's dirt, and you're sealing it in.
USING THE Z-18 CLAYBAR
Before using a Z-18 ClayBar on your car, you must thoroughly clean and dry your car to remove any loose dirt. Direct sunlight should not fall on your car's surface, and it's best if the work area is relatively cool to prevent rapid evaporation of the clay lubricant.
To use the clay bar, you spray a water-based lubricant (1/2 a cap of Z-7 Show Car Wash with 16 ounces of water) on a small area of your car and rub the bar back and forth with light to medium pressure. Z-18 ClayBar should glide across your paint like a hockey puck on ice. If the lubricant begins to dry, and the Z-18 ClayBar begins to drag, you'll need to spray more lubricant. Clay is fairly sticky, and cannot be used dry.
After a few passes with the ClayBar, rub your hand over the area to feel if the surface contamination was removed. Keep rubbing until all contamination bumps are gone. Finally, wipe the clay residue off with a soft terrycloth towel, and buff to a nice luster. Just like waxing, work in small areas.
Check your Z-18 ClayBar frequently for hard particles. When found, pick them off. Make it a habit to occasionally knead and reform the bar so that a fresh portion of the bar contacts your car's paint. If you drop your bar of clay on the ground, it's history. Toss it out. Don't take any chances, discard the clay bar if it becomes impregnated with grit. Read the manufacturers' directions for the number of uses of their clay bar. Do not overuse a clay bar.
When you're finished claying your car, you should wash it with Z-7 Show Car Wash to remove the lubricant film. Finally, polish and seal your freshly cleaned paint with your choice of Z-2 Show Car Polish for Clear Coated Car Finishes, Z-3 Show Car Polish for Non-clear Coated Paint, or Z-5 Show Car Polish for Swirl Marks and Fine Scratches enabled with ZFX™ Flash Cure Accelerator Additive.
--From Zainobros.com
You should wash your car with Dawn liquid soap before claybar to get all the wax off because it is an alkaline soap. Trust me if you do this before you use clay your car will look awesome.
If I remove the wax beforehand, will it be more beneficial when clay bar without wax?
Poop or anybody else, can you validate this?
yes, remove wax before claying, then after you clay wash your car again, then wax :)
Hm...well I was planning on claying as well...I bought the meguiars quik clay system. Is there any real benefit to removing wax first? I was planning on just washing it with my gold class wash, and then just claying...
Wash the car with dishwashing detergent before claying, in order to strip off the old wax. The bennefit of removing the wax is that it acts as a layer in between the paint and the clay. You need to remove that layer before actually getting to the paint.
Discussion Starter #10
That was my hypothesis, but then again, I did not want to do an extra step if I did not have too. That means I have to take a bucket of dish soap to the car wash…
Have a fun weekend! when I clayed my car, with all the steps and if you added all the time in straight hours worked came out to 10 hours total of work!!!! That was pre-wash to remove wax, dry, then clayed, wash again & dry, and waxed 2 coats!
the clay will remove your wax don't worry, just wash and then clay. Meguiar's makes good prodcuts, especially the Mirror Glaze line, but that clay isn't that great, for a consumer clay I prefer the Mothers or Claymagic over that one.
use Dawn liquid soap it's high-alkaline content helps break off the wax.
Discussion Starter #14
I bought the Mother's, and for my best results, I am going to wash it with dawn soap, since you have to wash it anyhow...
I would agree with everything said here, including the fact that you should remove the wax. I do not reccomend that anyone use Dawn dishwashing liquid on their car. Dawn dishwashing liquid is designed to wash dishes, not the delicate finish on your car. You should rather use a product from Mother's, Griot's Garage, P21S or Pinnacle that is desinged to remove was. Pinnacle is by far the best. (But rather pricey too!)
Discussion Starter #17
My car is now nice and shiney...
I used the clay bar, and added 4-coats of Zaino, and fought with the lil lady the rest of the time, because she was bitching that I should treat her and spend more time with her like my car... :crazy:
:lol:
the dawn wash is overated. It is not necessary. Yes it will strip all your wax, but so will a clay bar and polishes. Use a quality car wash, P21S has a nice one and a good cheap one is the Meguiars Gold Class Wash.
1 - 19 of 19 Posts
