Information for this article was compiled from reports and studies by the University of Nevada Desert Research Center, DuPont Chemical Company, Avco Lycoming (aircraft engine manufacturers), North Dakota State University, Briggs and Stratton (engine manufacturers), the University of Utah Engineering Experiment Station, California State Polytechnic College and the National Aeronautics and Space Administration's Lewis Research Center.
Road Rider does not claim to have all the answers. Nor do we care to presume to tell you what to do. We have simply tried to provide you with all the information we were able to dredge up on this subject, in hopes it will help you in making your own, informed decision.
You Can't Tell The Players Without A Program
On starting this project, we set out to find as many different oil additives as we could buy. That turned out to be a mistake. There were simply too many avail able! At the very first auto parts store we visited, there were over two dozen different brand names available. By the end of the day, we had identified over 40 different oil additives for sale and realized we needed to rethink our strategy.
First of all, we found that if we checked the fine print on the packages, quite a number of the additives came from the same manufacturer. Also, we began to notice that the additives could be separated into basic "groups" that seemed to carry approximately the same ingredients and the same promises.
In the end, we divided our additives into four basic groups and purchased at least three brands from three different manufacturers for each group. We defined our four groups this way:
Products that seemed to be nothing more than regular 50-rated engine oil (including standard additives) with PTFE (Teflon TM) added.
Products that seemed to be nothing more than regular 50-rated engine oil (including standard additives) with zinc dialkyldithiophosphate added.
Products containing (as near as we could determine) much the same additives as are already found in most major brands of engine oil, though in different quantities and combinations.
Products made up primarily of solvents and/or detergents. There may be some differences in chemical makeup within groups, but that is impossible to tell since the additive manufacturers refuse to list the specific ingredients of their products. We will discuss each group individually.
The PTFE Mystery
Currently, the most common and popular oil additives on the market are those that contain PTFE powders suspended in a regular, over-the-counter type, 50-rated petroleum or synthetic engine oil. PTFE is the common abbreviation used for Polytetrafloeraethylene, more commonly known by the trade name "Teflon," which is a registered trademark of the DuPont Chemical Corporation. Among those oil additives we have identified as containing PTFE are: Slick 50, Liquid Ring, Lubrilon, Microlon, Matrix, Petrolon (same company as Slick 50), QMl, and T-Plus (K-Mart). There are probably many more names in use on many more products using PTFE. We have found that oil additive makers like to market their products under a multitude of "private brand" names.
While some of these products may contain other additives in addition to PTFE, all seem to rely on the PTFE as their primary active ingredient and all, without exception, do not list what other ingredients they may contain.
Though they have gained rather wide acceptance among the motoring public, oil additives containing PTFE have also garnered their share of critics among experts in the field of lubrication. By far the most damning testimonial against these products originally came from the DuPont Chemical Corporation, inventor of PTFE and holder of the patents and trademarks for Teflon®. In a statement issued about ten years ago, DuPont's Fluoropolymers Division Product Specialist, J.F. Imbalzano said, "Teflon is not useful as an ingredient in oil additives or oils used for internal combustion engines."
At the time, DuPont threatened leg
