those numbers look a little lean for driving hard....especially if it is a very hot day & you are hammering the car... in cool weather & those numbers are not too bad, good for power and decent mileage.... but if it gets Hot on you set-up like that you could go lean @ WOT, & that is not so good just dont push it too hjard when it gets hot with that setup...
a 14.7 ratio is "perfect", as they say for optimal fuel combustion & power production etc, but even with the Ecu & computers on these cars today... ou never really run that lean in real world conditions when driving really hard i dont think... at least not safely
it is so hot here we are set up to run a safe 11.8-12.5 ratio during full power runs & boosting 7+ psi...
when it cools off a bit we will retune for a slightly more agressive ratio for better mileage & more optimized power from this setup....
the KILLER thing is that with my Ver.7.0 LMS I-manage, & Wide band AF ratio monitor/ display we can adjust the setup any time we want to richen or fatten up the AF ratio for power or safety, & this thing is still under development... it will be pretty freaking SICK when we are done...LOTS of really cool features to come that are JUST barely starting to be seen on other high end Fuel management setups.
