Is keeping your ac still doable when boosting engine ? Currently doing a build looking for 375-425 HP . Thanks 2004 IS300
Yep AC will work fine with turbo. Look at all the turbo Supras and Aristos with factory AC. What I’ve read can cause problems is doing a high rpm pull and breaking the AC clutch. Make sure AC is off if you’re going to go past the stock rpm limit during a pull.
Awesome fellas thanks my compressor took a dump so I’m doing a build on another spare engine don’t wanna get another compressor for nothing , makes sense tho ! Thanks again
