Hey guys, I was driving on the freeway yesterday with my a/c on...and all of the suddent, the A/C light kept blinking!!! Do you guys know why it did that? :eek:
Did the AC keep working? :-?
Did it blink as in turning off all the way or dimmed? :-?
Wow thats really weird. The only thing I can thinkof is....
1. The light is a malfunction indicator for the A/C system or..
2. The actual light bulb (or led, i'm not sure which) has gone bad and needs ot be replaced.
Either way, you shouldn't have to worry about it. Take it to the dealer and let them deal!
Check your manual. It says if the AC light blinks there is a problem with the AC system and should be checked by your dealer.
Blinking ac lights
How about other dash lights? Blinking or just dimming. If the headlights come on the dash lights dim because they don't have to be as bright in conditions where the headlights have to be turned on.
When I pull out of my garage, my headlights turn off and the ac light indicators brighten.
Discussion Starter #7
The light kept blinking on the a/c button only. I just decided to to turn off and turn it back on, then it worked again fine again.
so weird!!
puzzled
