You gonna have to redo the downpipe with the new turbo manifold?
Meanwhile this my forecast:I also want to delete my heater core
Yup. I want to do a 3.5" or so, it would sound really good and it has been proven that a bigger downpipe aids in spool. For the time between then and later, I plan on taking the hood off and flipping my current downpipe upside down and chopping it so it sits nicely haha. It should be really obnoxious for a bit, but it'll just be a placeholder. Hope my parents don't kick me out over it lol.You gonna have to redo the downpipe with the new turbo manifold?
Turns out something went wrong after I swapped the ballasts on my lights. Took the offending light out then fixed up the wires. Works great now. Strange that it didn't work for the first few tries, on the other light, that was kind of a head scratcher.At least it's not the ballast. You definitely get what you pay for with lighting. I guess you could use one bulb of each for now lol. IDK about the customer service with Z1 Motorsports, but when I used to get Morimoto from TRS and something went wrong, they made it right.
What, no polishing? 🤭First package that came contained a brand new set of GTE VVTi valve covers. I have some plans for these, but not what you'd expect. I want to shave down the sides, get them smooth and have them painted or coated. I also really want to use the middle larger PCV openings as tucked catch can lines.
Not this time. I'm sure they will be at some point and I'll be doing 90% of the polishing work anyway, but I want them painted along with the cam cover. I'm thinking a silver color similar to stock, but I want a different finish. I'll have to look at other people's setups to see what I can put my spin on.What, no polishing? 🤭![]()
Awesome info; wish I'd known it 6 months ago. If I'm seeing your picture correctly, the only mismatch between GTE valve covers and GE head is one bolt on the outboard side of the exhaust cover.The only issue with GTE covers on a GE head is this right here. One of the holes doesn't line up right.
This is correct. Every other hole is in it's correct position except that one.Awesome info; wish I'd known it 6 months ago. If I'm seeing your picture correctly, the only mismatch between GTE valve covers and GE head is one bolt on the outboard side of the exhaust cover.
Which implies the IGN1A smart coil brackets designed to jive with the valve cover bolts will fit the GE head.
That's a good idea and would be the proper way to do the retrofit, but I might just remove it entirely and run a little silicone along it. Should be fine. I'm neither the first or last person to do this, so I'll do some digging.If your'e willing to spend some time grinding/sanding/finishing, I'd think it'd be pretty straightforward to cut off the existing ear that's in the wrong spot - and weld a new one on in the right spot. Then drill the hole, file it all flat, sand it to match...
I appreciate your offer and if I didn't already have a local guy I'd consider it. I can bother him easier and he's only a 10 minute drive from my house.I'll powdercoat your cam covers if you want. I have wrinkle black and metallic silver - but I'll coat them with any powder you send my way.
