Of course, I have some cool new stuff coming in the mail. I also have some cool old stuff in the works. I'll update when it comes in or when I get this side project working.
Thanks! I like the V1 because it keeps the fog lights and makes the front end look a lot less round. The skirts are smooth and straight, which I think flows with the door garnish really well. The rear lip is like the TRD just smoothened out. I feel it's perfect because these cars don't have overly aggressive lines to begin with. And the polish isn't so bad, just pull off the dull pieces and shine them up again. Or don't, it looks great all chrome like, but I also like when it's all a little dull too.Been following your thread for a minute, your commitment to polish gives me anxiety cause I could never. I think in it’s current form your car looks great, I don’t see the hype for the V1 but that’s just me. As long as it gets driven it’s a thumbs up from me.
Whatchuplanning to do in there? Stock ecu delete? I deleted all the unnecessary wires this summer when I had the motor out. It gets pretty crowded in the ecu box. I love Tesa tape and braided loom.y. It used to look terrible under there, but it's gotten better. Soon, it'll be completely hidden.
Precisely. Just thinning it out for now to make it easier for when I shove it all under the dash lol. This thing is gonna take it's place vvv. Tesa tape is a godsend. (Yes, I know this is the worst photo ever.)Whatchuplanning to do in there? Stock ecu delete? I deleted all the unnecessary wires this summer when I had the motor out. It gets pretty crowded in the ecu box. I love Tesa tape and braided loom.
I'm not super convinced that's true... but if it is, the attention to detail of the division is absolutely critical; any leak or cross-talk between the two banks, anywhere from exhaust ports to turbine, will negate the benefit of division.before I learned that a T4 divided helps non-divided turbos (of course).
Thanks for checking it out, I'm looking forward to it also.I look forward to seeing the engine bay buttoned up
If I'm really that concerned, I'll just buy a QSV. Or I can get a real tune lol.I'm not super convinced that's true... but if it is, the attention to detail of the division is absolutely critical; any leak or cross-talk between the two banks, anywhere from exhaust ports to turbine, will negate the benefit of division.
If I ever were to do a QSV I'd have to take that into consideration. Ideally there should be more room than however tall a QSV is between the chassis and the exhaust anyway. I probably won't get one. A professional tune on E85 will do just fine for me.will the qsv move turbo, thus the down pipe and thus the exhaust upwards a little? the exhaust hangers will have enough give to accommodate the slight angle lift?
Thanks! I feel it could be better and paper is pretty cheap so I can do some experimentation. As for patience, it's hard. You just gotta see it through that's why I gave it some shine on the first day I got mine, I had to convince myself. Since I'm happy(ish) with how the runners look, I can clean up the standoffs and injector areas, then I'll call it good. The hard part is pretty much over now.That polishing looks solid; I absolutely, positively do not the patience required to do that job.
That’ll be a nice build, man. What will that HG put your compression at? Take pics of the big rewire!Pulled the new one all apart and it's getting a little build soon.
Thanks! I believe the HG will put me closer to 9.1:1 like the pistons would suggest. My block is decked very minimally and the head on the GE VVTi has a lot of height in the quench(?) zones, unlike a GTE one. Stock TT gasket is 1.3mm and the Tomei one is 1.2mm. This should get the geometry closer to ideal, while still remaining very safe. I will take many pictures of the big rewire, hopefully a lot of pictures of nothing!That’ll be a nice build, man. What will that HG put your compression at? Take pics of the big rewire!
