Im not sure if this is the right place to post this but if it isn't my badd..
Anyways i was wondering if one of the 2jz-ge engines would be able to swap in without an major problems? if not any one know what would fit fairly easy with moar powrr
Thanks again..
Your post is unclear. What motor are you trying to put in what car? Otherwise I'll assume you are asking to swap a motor into your 01 IS300 that's in your sig.
Honestly, it depends on your goals and budget. Can you swap one? Yes but it might cost a lot. I have no clue how much support is out there for it (engine mounts, wiring harnesses, etc). If you want a lot of power for a truck, there always seems to be someone swapping an LSx motor into something.
