Hello,
I read a lot of posts stating that OEM 17" wheels require 12-15mm spacers for the front to clear the LS400 brake calipers, but I think most people are referring to factory 5 spokes.
I know that the specs are 50mm offset for the 5 spoke and 11 spoke front factory wheels. However, wheel design and back spacing are another variable that matters.
Does anyone know if the 11 spoke wheels give more back spacing, and would allow LS400 front calipers to fit without the 12-15mm spacers?
I prefer to avoid spacers if possible.
Thanks!
Do you know what size of minimum the spacer is required to clear these Sport Design wheels?
Put 15mm on all fours. Front needs it, and when rear matches looks a bit more aggressive.
