For those who want to do most of the 60k service on your own, I have created this thread and the attached links so that you can pick and choose what you want to do. I tried to document as closely as possible the procedures taken in each procedure. I have also tried to document prices, part numbers, time taken, and effort required.
General consensus says that you do the following things:
Oil/Filter Replacement If you are at your oil change interval.
Skill Level: Beginner
Tools Needed: Minimal
http://my.is/forums/f87/oil-change-diy-lots-pics-printable-pdf-attached-264598/
Coolant Replacement
http://my.is/forums/f87/radiator-drain-refill-diy-pictures-256156/
Power Steering Flush
Skill Level: Moderate
http://my.is/forums/f87/power-steering-fluid-flush-diy-w-lots-pics-256159/
Transmission Fluid Replacement
http://my.is/forums/f87/transmission-tranny-drain-refill-flush-diy-pics-included-printable-pdf-attached-254631/
Differential Fluid Replacement
http://my.is/forums/f87/differential-diff-fluid-replacement-diy-lots-pics-printable-pdf-attached-254397/
Inspect Brake Pads (Replace if necessary, 1mm is the minimum pad thickness before replacement)
Tools Needed: Moderate
http://my.is/forums/f89/brake-pad-rotor-replacement-diy-lots-pics-pdf-instructions-now-attached-255699/#post3493206
Brake Fluid Replacement
http://www.stoptech.com/whitepapers/howtobleedbrakesright.htm
For the IS you need a 10mm wrench and a 12-14" length of 1/4" clear tubing
Spark Plug Replacement (if you have Platinum and not iridium plugs)
http://my.is/forums/f87/spark-plug-replacement-diy-lots-pics-printable-pdf-attached-254217/
Fuel System Maintenance
I use BG44k before I change the oil which is a total fuel system cleaner.
Replace PCV Valve
Replace Oil and Filter
Replace Air Filter
Replace AC Cabin Filter
Lubricate hinges
Rotate Wheels
Inspect/Replace Serpentine belt. For some reason I could not get the pulley to move so I am going to pay someone to do this for me. I know,.... it is supposed to be easy, but I was not able to do this one.
Things you probably cannot do on your own
Balance Tires (Subjective, if you need it, do it. If not I would skip it and wait until you replace your tires)
Alignment (Subjective, if you need it, do it. If not I would skip it and wait until you replace your tires)
Torque drive shaft bolts
Common Questions:
Q: How much does the dealer charge?
A: Based on everything I have ever read on this car, the 60k costs between $800-$1200 at a Lexus Dealer and $500-$700 at a Toyota dealer (if you can find one that will work on a Lexus)
Q: How much will a DIY cost, what do I have to buy, where did you get it?
A:Item Description * Cost * Purchased From
(1) Gal Coolant PN 00272-1LLAC-01 * 15.95 * Toyota
(6) Spark Plugs * 71.70 * www.sparkplugs.com
(2) Qt Mobil 1 Synthetic 75/90 GL-5 rated * 19.70 * Local Auto Parts Store
(3) Toyota Type IV Tranny Fluid (Drain Refill) * 11.25 * Toyota
or
(10) Toyota Type IV Tranny Fluid (Flush) * 37.50 * Toyota
(1)Transmission Drain Crush Wash PN: 35178-30010 * 1.80 * Lexus
(2) Differential Drain/Fill Crush Wash PN: 12157-10010 * 1.68 * Lexus
(2) Qt Valvoline Dextron III ATF * 2.49 * Local Auto Parts Store
Accessory Serpentine Belt PN 99366-D1930 * 36.95 * Lexus
(6) Qts Mobil 1 Synthetic 5/30 * 24.95 * Costco
(1) Oil Filter * 6.95 * Lexus or www.irontoad.com (cheaper @ irontoad but I found out too late)
(1) Can BG 44K * 18.95 * Acura Dealer (Purchased a while ago can't remember if the cost is exact)
(1) Bottle Valvoline SynPower Brake Fluid * 8.95 * Local Auto Parts Store
(1) PCV Valve * ??.?? * Lexus (Did not replace it)
Apx Total Cost (with a tranny flush) inc. Sales Tax @ 7.75% $300.00
Add cost for AC Filter, OEM Air Filter, Alignment, Balance if necessary (I did not need them)
Balance generally $7 per wheel
Hunter Laser 4-Wheel Alignment generally $69.00
AC Filter $16.32 @ www.irontoad.com
OEM Air Filter $12.74 @ www.irontoad.com
LMK if there are any questions, I would be happy to try to answer them.
If you have any suggestions on how to make this thread better or if any of my procedures are incorrect please do post, I would be happy to make adjustments.
Thanks.
Coolant Replacement
Replace PCV Valve
Replace Air Filter
Lubricate hinges
Rotate Wheels
Common Questions:
or
Thanks.
