CharlieD06 said:
what clutch are you guys running?
will a stock tranny w/ RMS 6puck Clutch take 450 RWHP (toyomoto stage 2)
Make sure you are using the appropriate clutch/pressure plate for the mkiv supra, and not an IS300 clutch...
Also, figure out what kind of flywheel torque you will be putting out and select a clutch based upon that figure.
-C
ltuned&boosted said:
Umm i have an rps 6 puck clutch in my six speed and I had to swap out the stock flywheel for a lightened flywheel because they did not fit together.
Good point Aldo- The reverse is also true- some of the clutch/PP combinations do not mate up appropriately with the lightened flywheel combos. So double-check every part to make sure they are compatible.
-C
How do you find pedal feel and quality of "take off"? I have a 6 puck and a high pressure pressure plate which is a little "grabby" and chattery if not handled right. It is also rather heavy, not that good for traffic.
Penetration Specialist
I'm doing this also...RPS 6 puck and lightweight flywheel. Can't wait!
