1 - 8 of 8 Posts
Here is a list of what they did to my car:
Replace engine oil and filter
Rotate Tires
Inspect air filter
Inspect front and rear disc brakes
Inspect steering linkage
Inspect Drive Shaft Boots,
Re-torque flange boots (on applicable models) ?!?!?!
Inspect obdy and chassis nuts and bolts
Inspect drive belts and hoses
Inspect fluid levels
Test Drive
Wash....(they did a shitty ass job as usual, no more dealership wash)
According to the printout, they used 4 Quarts of BT 10W30 Motor Oil. I checked the prices of their engine oil to be $3.50 per quart, kind of cheap.
I thought it was suppose to be like 6 quarts.
I reprogram the key to one push access for all door, and supposely he told me that the doors will lock automatically when in D mode, but that change was not implemented, didn't realize that opion was available either.
I told the service manager about the caps on the rims that was peeling, he told me that he was going to order me a new sets, and call me when they're in.
hey.. i was curious as to what mods did you have on your car?
did they check your aftermarket airfilter or stock.. and did they
bitch abt your aftermarket parts? cuz when i went in for servicing
with my 2003 civic, they bitched it was lowered.. and exhaust and
intake so they wouldnt service my ride.. gh3y..
thanks for the info, buggin! i'm going to ask about my centercaps as well as the auto-lock feature in D.
i'm coming up on my 5K in about 2 months...
IS300 uses 5.8 qts of oil with filter.
I wonder if the filter got changed.
I believe i saw the mech changed the filter.
He pulled something out of a box, that looks like a filter.
But like i said, if the IS uses 5.8 quarts, how come i only got 4 quarts according to the worksheet?
ThunderCloud....i just spoke with the service guy, and he told me that locking the door automatically on D mode, won't work.
buggin, thanks for the follow-up! too bad it won't work!
1 - 8 of 8 Posts
