You'll be getting a survey to fill out shortly. express your dissatisfaction on there.
Alignment and wheel balancing are 2 different things. If the car wasn't exhibiting a shimmy before going in and they "balanced" the tires or rotated them it could be due to that and not a bent rim. Another possibility is they did a 5 tire rotation and the tire that was in the trunk has a problem.Originally posted by SophieSleeps:
A wheel straightening company told me that usually when you have shaking and stuff, it's not due to alignment but due to a bent wheel.
Alignment they said usually makes the car pull to a certain direction or miscalibrates the centerline of the steering wheel.
Originally posted by chitownman:
I just got my 5k check up last Sat at a local dealer here in Chicago. I waited two hours - instead of the expected one hour to get my car back. The excuse I was given was that the engine was too hot to replace the oil. I only drove 3 miles to the dealer. On top of that they didn't clean the wheels. Now my steering wheel shakes/vibrates at high speeds around 50-60 mph. I'm guessing this is a wheel balancing problem. Isn't tire/rotation - wheel balancing part of the 5k service ? I now have an appointment on Monday evening to let them take a look at this. Does anyone here think this is acceptable service from a Lexus dealership?![]()
What Dealer did you go to?Originally posted by chitownman:
