1 - 8 of 8 Posts
Hey guys I have had my car for 3 weeks (20kmiles) and have been playing pretty rough with it. There has been two times when Ive been getting on it and the clutch has stuck half way and ive had to let off on the gas slam it down and then it will get going again.
Now I searched and read if anyone else had this problem. Seems that it is a built in feature so people are running around dumping the clutch ?
Is it worth removing the CDD? Does anyone have a step by step process for this?
Not sure if i should do this or just try to learn the limitations of how much I can rag on my car :) Another thing, this seems kind of dangerous, lets say i pull out into traffic with intention of letting loose on the ride and this CDD kicks in and im a sitting duck?
Can someone fill me in a little more on this?
These are the resources i have used to get my info thus far.
http://www.is300.net/modules.php?name=Forums&file=viewtopic&t=13338728&highlight=sticky+clutch
http://www.is300.net/modules.php?name=Forums&file=viewtopic&t=13296961&highlight=sticky+clutch
http://www.is300.net/modules.php?name=Forums&file=viewtopic&t=13321227&sid=a90b486a42821390f3ac454c99192375
I have experienced the CDD and it's a "Lexus" type of idea to make the car "Lexus-like" and smooth shifting. I know sometimes the clutch will hang about 70% of the way out for a second (like you feel a little hang in the pedal when you lift your foot up)... but I don't believe it should be sticking as you are describing. I'd have that checked out. And the dangerous traffic thing.... again, I'd have it checked out - to my knowledge it's not supposed to "stick" like that. That's unsafe. :eek:
Hmmm
Yeah it will stay like half way for like at least a second or two.
Its happened twice.
Then i have to either slam it down or try popping it up by putting my left foot under it and lifting up. I guess what the CDD is doing is not as noticable as what i am describing?
Thanks for your input...
Thanks man
Wow nice article, This is my third manual that I have owned so I know that this mod will make my IS feel a lot better then it does right now. I am very excited about doing this but pretty scared about all the warranty void talk.
Anyways my question is answered thanks a lot!
I had this same issue... Check the hood release cable, mine was in the way of the clutch pedal and not letting the pedal all the way back up.
I had a similar experience when dropping it into 2nd to take a corner. After I lifted off the clutch and jumped on the gas, the clutch didn't disegage completely and I ended up getting a nasty smell. I had to let off the gas so that the clutch could slowly disengage. I just recently did the CDD mod with a couple of other members on this board. It took very little time to completely do everything. 15-20 minutes should be all you need. Now the clutch engagement/disengagement is so much more responsive and predictable. It's also simple to reverse the process so you shouldn't worry too much about the warranty issues.
I too had a similar experience where my clutch did not release until i kicked it up with my left foot. I too had the nasty smell and decided to take it to the dealership the same day. Apparently lexus has had to deal with this type of thing on many occasions. I told the service manager my story and within 5 minutes he diagnosed that I needed a new clutch and flywheel which fortunately Lexus replaced free of charge. I don't know if this is the exact same thing that happened to you, but just something to think about.
1 - 8 of 8 Posts
