Okay for many of you that have subs in your trunk and have already used dynamat in the rear speaker deck, how have you solved the rattle problem with the third brake light? Since the damn thing uses a standard bulb, I have limited options of stuffing the light to prevent rattle to later have a difficult time replacing the bulb. I've tried using an LED bulb from superbrightleds.com, but the bulb neck is too wide and doesn't sit properly resulting in the damn bulb warning on the dash. Does anybody have recommendations for sound deadening it? How about some company out there that makes a complete light and housing replacement that uses LED lighting and has not rattling problem? Anybody with some good ideas would be greatly helpful.
