1 - 8 of 8 Posts
· Premium Member
was looking aroung MKIV.com a couple of days ago...followed a link to powerhouseracing.com and saw they had a turbocharger for the IS...wrote them an email and this is what I got back this morning...
Sir, we do offer a custom built turbo system for the IS300. A basic system
that offers about 300 HP would cost $7500. The next step in performance
would be 400 RWHP at a cost of about $11000. There are no supercharger
kits available for the IS300 as of now. The turbo system replaces the
headers, intake, etc. We also offer a fuel system upgrade and ECU
modifications for the turbo system. Labor to install a system is about
$1500-2000. Thanks
Jarrett
http://www.powerhouseracing.com
too bad i don't got 11000 to throw into my car right now...400rwhp sounds pretty tempting
· Registered
Another thing you want to check for is if your getting a new head gasket to lower the compression ratio. Check out www.suprastore.com, they have a 2JZ-GE turbo kit and they are sellin it for $4,750. This kit will get you up to 320hp, stock Supra Turbo hp that a little better deal than $7500 for 300hp. Then after a little more engine work you could be pushing as much as the supras do.
· Registered
It all depends on how complete the kit is. Many cheaper turbo kits still leave you with having to do fuel system upgrades, adding and intercooler and associated plumbing, blow-off valve, external wastegate if the turbo doesn't have one integrated... and so on. Doing a good quality turbo install costs serious money. Assuming you are supplying enough fuel, and you can keep detonation at bay, you can go well past 500 rwHP. My advice is to spend your money wisely and get it installed by a pro with many custom turbo installs under is belt.
· Registered
Thats what you get. Follow the link I posted you it's under Supras NA(non-turbo)
PARTS LIST
High Carbon Cast-Steel Turbo Manifold, 3” Mandrel-Bent Downpipe w/ Closed-Loop Wastegate discharge, Intercooler Tubing, Turbocharger Intake System, All Necessary Hardware and Fittings.
TURBO ASSEMBLY GARRETT/Turbonetics T04E-60 Turbocharger, HKS Standard External Wastegate, Large Front-Mount Intercooler(28x6.5x3.5), HKS Racing Bypass Valve (blow off valve), K&N Air Filter, Oil Cooler, Transmission Cooler, Turbine Heat Shield.
FUEL MANAGEMENT Additional Injector Controller, 440cc Lucas Fuel Injectors (2), 3 Bar MAP Sensor.
DETONATION MANAGEMENT 8.5:1 Compression Ratio Head Gasket
· Registered
The Suprastore kit does look pretty good. What I was trying to say is that before people get all excited over the price of a kit, they need to look into what that kit contains. Many cheap kits for Civics and Integras and the like, only come with a turbo, exhaust manifold, and wastgate. leaving you with a lot of work to do and more money to spend. People also don't need to be put off by what may appear to be small HP gains. Many turbo kits are set with a conservitive 5-8 lbs of boost, though they may be capable of going much higher. A good rule of thumb is that at roughly 16-18 lbs of boost you will see a 100% increase over stock HP. :)
· Registered
That turbo seem kind of big for everyday driving. Does anyone have a T03 or T02 turbo? I think this is more suitable for street driving. Of course, you cannot generate massive boost with these turbos.
So how many people are willing to volunteer to try the turbo system out?
1 - 8 of 8 Posts
