2jz = type of block, 2nd generation of the JZ series
G = performance oriented head/cam design
T = turbocharged
E = fuel injected
the differences are:
GTE has oil squirters
GTE has thicker/better rods
GTE has lower compression pistons
GTE has a different port position head, as well as flow design
GTE has a different intake manifold
GTE has a water coiled oil filter housing
GTE has the p/s pump mounted in a different position
GTE has 2 cam sensors
GTE has no vvti (american spec)
GTE is not drive by wire
GTE uses different motor mounts (interchangable dependent on year)
GTE uses a different lower girdle/oil pan, oil pump sump and oil level sending unit
GTE uses a different oil pressure sending unit
GTE uses a fuel return system
i'm probably leaving a few things out, but you get the picture
-gte
WRECKEDIS300 said:
My goals aren't in the 400hp range. I was hoping on someday making 350hp. Though money is a problem right now. Down the line I will definitely make around 400hp but not now. I was wondering because the T in GTE stands for turbo (from what I have been told) so I was thinking that the GE was the same as the GTE just without the turbo. Also I've heard that with a valve job on the tranny it will sove the shifting problems. IS this true?
