1 - 9 of 9 Posts
Will this be a good tire size for an 8.5" wide rim? I just ordered a set of rear tires and i just wanted to confirm that it will fit. Thanks in advance.
depends on your offset,I have 18x9 w/55 offset and I have 255/35/18 and I don't rub even w/2 people in the back and I'm lowered on eibachs and bilteins.
i think it is +48 in the rear.. but im not sure ive got the tein ss drop, but its not really dropped too much
i have a 18 x 9.5 inch rim, 55 offset, with 255/35/18 tire. no rub, even with tein stech drop. even with a ton of shti in the trunk, no rub, not even close. im going witha 275 when i get new tires in the spring.
I had 255/35/18s on my car (18x8.5 with 42 offset) with Hotchkis drop, I was rubbing during bumps. I had to switch it back to 235s. I am trying to get rid of my 255s, if you need a pair let me know! ;)
Apricot idea killer
I think he's not askine about rubbing, just if it's a good size for the RIM ITSELF. (yes, it is btw).
jvillagran2000 said:
I would get 255/30/18 if I were you.
I dont think there is a size, but I might be wrong. 255/35 is the only way to go, you wouldnt be able to find a tire size to match up in the front with overall diameter.
255 wide on a 8.5" wide wheels is fine, but should not go any wider than a 255 wide tire. I ran a 255/35/18 on my Volks CE28n 18x8.5.
1 - 9 of 9 Posts
