1 - 13 of 13 Posts
TK288 said:
Enevel12 said:
more than likely not. try 225/45/17, or 235/40/17
does 235/40-17 fit on the stock rim with stock height?
I'm sure it will fit, but not sure if it's too much tire on the stock rim. hopefully brandon from tirerack can chime in on this as he would be more educated on proper fitment. Im' sure it would be good on the 7.5 inch sportcross rear, but not sure on our 7 inch stockers. why not do the 225/45 that works fine.
can't stand the tirewall being higher... :pissed:
I assume you are looking for more traction?
Instead of investing in a wider tire, go for higher performance, stickier tires...it'll give u all the traction you need without resorting to some irregular size.
1 - 13 of 13 Posts
