Hi folks,
I've had this shell sitting in a autobody storage outdoors for many years.
I got a call today from the shop owner and said he's moving out, which means my shell has to go.
I have about 1 week to get it out.
These are the parts that are in it. Obviously the shell has been sitting for quite some time, but 95% of the parts are probably in good shape.
Im going to post a list of what I have.
I don't have the ability to part it out. Only a complete shell sale will work here.
Any questions let me know.
Im working on getting pictures and will update later, but for now I only have a parts list.
Engine Harness
Fully Customized Dr. Tweak Tucked Engine harness and Chassis Harness outside of the car
Exterior Body
Full Engine Bay Shaved and Painted
I believe it still has RMM sideskirts and L-Tuned rear bumper valence
Rear End
GS400 Carrier Differential (For 3.266 Gear Ratio) (Painted and Cleaned w/New Seals)
Custom CNC Differential Plate Cover with Mounting Points
TRD Limited Slip Differential
Toyota Supra TT Halfshaft Axles
Tach Motor Works Custom Rear End IS300 Conversion for GS400 Differential with Chromoly Braces
Driveshaft Shop Custom 3.5" HD Chromoly Driveshaft with Billet Adaptor plates
Suspension
Custom KW Coilovers Variant 3 with Custom Spring Rates and FIGS Lower Solid Press in Bearing
Tanabe Front SUSTEC Underbrace
JIC Magic Strut Tower Bar
Cusco Rear CF Strut Tower Bar
PLP Trunk Brace
SPC FRONT CAMBER KIT and REAR CAMBER KIT
Eibach Front & Rear Sway Bars
FIGS Front and Rear Moto Endlinks
FIGS Powdercoated Red Crackle -- Rear MEGA LCA ARMS w/ Moto Rod End and Additional Gusseting
FIGS Powdercoated Red Crackle -- Rear MOTO Toe Links Set
FIGS Powdercoated Red Crackle -- Rear MOTO Trac Links Set
FIGS RCA HYSTEER Ride Height Neutral -> Stock Setting (For Bump Steer Correction)
FIGS STEERING RACK BUSHINGS #1 --- 2 bushings, 2 spacers per kit
FIGS STEERING RACK BUSHINGS #2 --- 1 Lower solid rest plus clam-shell urethane belt per kit
FIGS FRONT LOWER LATERAL ARM PRESS-IN SPHERICAL BEARING #1
TUNED PARTS - Custom Red Rear Subframe Rigid Bar Braces
ULTRA RACING - Fender Support Braces
Wheels and Braking
Wedsport Wheels 19"
StopTech Full Front and Rear Wheel BBK for 2.5" Lowering Cars includes:
-----StopTech 4 ST40 RED Brake Calipers
-----StopTech 355x32 Slotted & Zinc Coated Rotors
-----StopTech 4 SS Brake Lines
-----StopTech Street/Track Pads
Fragola Fittings and Lines for ABS Relocation w/SS Braided and Steel Brake lines
SuperBlueATE Brake Fluid
Supra MKIV TT Brake Booster Check Valve
Interior
AAC A/B/C Carbon Fiber Pillars
Custom Slanted Triple Gauge Pod by 2jzz
Valentine 1 Radar Kit with Concealer (Hardlined)
Full Silver Dash kit w/ Custom JDM Dash Silver Insert
Custom L-tuned Badge
Tuned Parts Illuminated Door Sills - Stainless Steel w/Amber Backlight
JDM Altezza RS200 Digital Gauge Cluster w/ Dakota Digital SGI-5, SGI-8, SVA Speed Corrector (KM->MPH)
JDM Double Din Dash kit
2003 Interior Door Panels with Chrome Ring Swapped
Chrome Interior Dials & Custom Silver Clock Trim from the UK
New OEM Interior Switch Panels
IS F-Sport Manual Shift Knob Custom Tapped to Fit on the V160 Shifter
OEM Manual Leather Shift Boot
Redline Manual Steering Wheel Re-wrap Slate Gray and Black 2 Tone w/Red Stitching
H3R HG250C Fire Extinguisher Chrome with custom bracket
H3R BMF01P Polished Mount
H3R BB250P Polished Band Clamp
Audio
Installation by Unexpected Creations - Don Amann (Top 100 Installer USA)
Kenwood DNX-9990HD w/HD Radio, Rear Camera, Ipod Wire, Sat Radio Upgraded Firmware
Focal 165 VR 2-Way Components
2 10" DYNAUDIO MW182 Subwoofers
Custom Infinite Baffle Sub Setup for the Rear Trunk
Stereo Clarity Deadened Baffles
Deadened Front Doors, Transmission Tunnel, Rear Trunk
Helix Competition German Amplifier - A4B
Stinger and Straight Wire Wiring
