1 - 2 of 2 Posts
I have found numerous threads on how to override the navi lockout when the car is moving for pre 2007 models. Does anyone know how to locate the service menu in a 07 IS or does anyone know how to disable the lockout function by simply pressing a series of buttons ? I have found theres a way to cut and splice wires to permanently void the lockout but I dont want have to perform sergury on this car. Any help would be greatly appreciated.
That feature was removed after the 06 models.
Supposedly if you have an 06 Nav disc and a newer one you can create a hybrid disc that will allow you to use the newer maps with the older firmware that allows the hack... but the physical wire bypass (or buying a plug-n-play version for a few hundred bucks) are otherwise your only options on an 07+
1 - 2 of 2 Posts
