I bought this sub and box from caraudiomasters in Charlotte in November, it is in mint working condition and comes with a pro-wedge box. This is a very clean, hard hitting sub. It is the new 07 W3v3 therefore it holds upto 300rms wattage thats 100watts then the v2 and flexes and extra inch. For more info please contact Mert @ 704-345-8959, please leave a message if i don't answer or send me a PM.
Thanks
Asking $175
Here are some specs and pics:
Product Description:
Best sounding W3 subwoofers to date
DMA-optimized, long linear excursion capability to virtually eliminate distortion and increase sound output
Perform outstanding in compact sealed or ported enclosures
DMA (Dynamic Motor Analysis) modeling to deliver unsurpassed dynamic stability and low-distortion operation within intended power range
Mineral-filled polypropylene upper cone with a metallic JL Audio medallion logo gives the W3's a whole new, classy and sophisticated look
RMS Power Handling: 75-300 watts
Impedance: 4 ohms
Efficiency: 87.15 dB SPL
Free Air Resonance (Fs): 26.72 Hz
Electrical "Q" (Qes): 0.472
Mechanical "Q" (Qms): 7.572
Total Speaker "Q" (Qts): 0.444
Equivalent Compliance (Vas): 2.844 cu. ft (not recommended box size)
Xmax Linear Excursion: 0.510 in. / 13.0 mm
Driver Displacement: 0.071 cu. ft.
Net weight: 14.50 lbs.
No warranty
Subwoofer Specifications:
Subwoofer Size: 12"
Dual Voice Coil: No
Impedance: 4 ohms
Peak Power Handling: N/A
RMS Power Handling: 75 - 300 watts
Woofer Surround: Nitrile-Butylene Rubber (NBR)
Woofer Composition: Mineral-filled Polypropylene
Sealed Box Volume: 1.25 cubic ft.
Ported Box Volume: 1.75 cubic ft.
Sensitivity: 87.15 dB
Frequency Response: N/A
Xmax (millimeters): 13 mm
Top Mount Depth: 6.65"
Cutout Diameter: 11.0625"
Warranty: No warranty
Thanks
Asking $175
Impedance: 4 ohms
No warranty
Subwoofer Size: 12"
Dual Voice Coil: No
Impedance: 4 ohms
