I have a 2003 is300 and it cranks but won't start. I have gas in the gas tank. I did the spark plug test and the spark plugs lit up. I checked the fuses and relays. I can smell fuel going into the chamber and see fuel on the spark plugs when I take them out to check. No check engine lights. I checked the timing marks. Just did the cam seals and crank seal. Car cranks but won't start. Checked the resistance on the crankshaft position sensor and it was good, checked the camshaft position sensor and the resistance was good. changed the fuel pump. Checked my timing marks again. Checked the fuses and relays again. Still only crank and no start. Crankshaft position sensor read 2k ohms. Checked fuel injectors resistance. None looked clogged or really dirty when I took them out. Can my timing be off somehow even tho my line marks all align correctly? Any help is greatly appreciated.
This is what is sounds like
