2002 Lexus 300 na-t
16421 Views 282 Replies 15 Participants Last post by  Pnut00
4
2002 Lexus is300. Northern Michigan, I plan to do a 15 - 20psi na-t build. I’m looking for anyone’s help or opinions with this build as I’m learning and researching all myself. Here is my car: (Last pic shows the current rims, just peeled paint off that the last owner put on)
Wheel Car Sky Tire Cloud
Automotive parking light Tire Wheel Vehicle registration plate Vehicle
Wheel Tire Car Vehicle Plant
Tire Car Wheel Vehicle Grille
See less See more
Reactions: 1
261 - 280 of 283 Posts
yea i found out about combo sensors surfing Platinum Racing's website, they have one that's by Syltek it's even smaller than bosch and has a steel body that's already 1/8 npt threaded and has Deutsch connector for only $125 cuz strong USD but you have to catch them with free shipping deal cuz they're in Australia
Reactions: 1
Just in case you wanna make that oil filter adaptor mount even fancier yet...
Bosch now makes a combined oil temp/pressure sensor that'd fit right where your existing AEM oil pressure sensor fits...
How would this work with my aem gauge? Would I need another one?
I'm not sure what AEM gage you have; is it a CAN gage wired to your ECU?
If so, using this different sensor would be simple. There's a good chance it's already a selectable choice in the Haltech software...if not, you'd just have to key-in the characteristic values of voltage/pressure that are included with the new sensor.
You'll also need an analog input to hook up the oil temp part of the sensor - this is two different sensors built into one - but it's still sending two separate signals to the ECU.
Reactions: 1
@keagan22 on the remote oil setup, do you have the lines routed out-out & in-in, or out-in & out-in? It’s hard to tell from the pics but kinda looks like you have it wrong.
  • Helpful
Reactions: 3
DEFINITELY worth checking.
Reactions: 3
its correct , did one at a time to make sure pretty hard to mess up they are labeled.
Reactions: 2
Pretty excited, I ordered the Grannas racing t56 swap w kit with the stage 4 Mcleod clutch
Motor vehicle Font Engineering Auto part Machine
See less See more
  • Love
  • Wow
Reactions: 4
So I finally sent my head out, went to powerdynamix decided to get everything done out heres what im getting :
CNC stage 2 porting
Frerrea Bronze Valve GuIdes
Frerrea Valve stem seals
Shimless buckets
Brian Crower BC0300HD Valve Sprinas and Retainers
Brian Crower 276 2JZ VVTI Camshafts
Performance head rebuild. Teardown , deep cleaning, competition valve job, set valve lash, install stem seals, reassemble head, resurface
Reactions: 2
CNC stage 2 porting
Shimless buckets
how much they want for doing valve guides?
Frerrea Bronze Valve GuIdes , Hand hone to size -$250
  • Love
Reactions: 1
that's not bad at all, i might as well do new valves with new guides too for mine. Thanks!
what's their lead time looking like?
Reactions: 1
Not too sure on that one your better off sending them a email or call
Reactions: 1
4
Got my head back! Porting looks great and they did very good job at everything
Automotive tire Motor vehicle Track Rolling Wood
Motor vehicle Automotive tire Hood Automotive exterior Engineering
Wheel Crankset Tire Automotive tire Bicycles--Equipment and supplies
Automotive tire Motor vehicle Automotive design Wheel Vehicle
See less See more
  • Love
Reactions: 4
Thats all CNC cut by the looks. At least you will know all the ports and chambers are exactly the same size
Reactions: 1
What manifold is that?? I feel like I should know but I’m still very new to is300 and 2js in general.
Reactions: 1
It’s from protunerz it was the only one like it for the price I can find
Reactions: 2
