Hi all!
I have a problem with my central locking. They key fob unlocks the doors as it should, but it doesn’t lock them nor does it open the trunk. Does anyone have any ideas?
The courtesy light is also always on if switched on the door mode.
I have checked all fuses, both under the hood and in both footwells. The dome light works as it should.
thanks in advance!
If it worked fine before. It may be a bad module. Check with a techstream and make sure the fob is addressed right to the module.
Sounds like a drivers side door switch issue. Pull the rubber boot off the switch in the door and replace it.
