1 - 2 of 2 Posts
$7000 firm
First come first serve.
The rear suspension is squeaking because of the heim joints in the lower control arms and toe links.
If you buy control arms and toe links with a rubber pillow bushing you will be golden for another 100k+ miles.
I'm just too lazy to deal with it and don't want to put more money into this car.
I'm going to just buy a hybrid after this.
Here's your chance to own a fun reliable sports car that'll last years if not lifetime if you keep up with maintenance.
Zero check engine lights
Clean title
Never any accidents
I am second owner ever
Only drive mainly to work 40 roundtrip per day not everyday
So many mods
A pile of paperwork documenting all maintenance and modifications
Smoke and pet free owner
Super clean interior
Everything works
This is not easy to find!
Fortune auto 500 gen 7 coilovers custom built. 13k front 9k rear with upgraded Swift springs. Barely put 400 miles on them.
Multiple alignments to get it perfect for daily freeway driving and for some fun in the turns.
Newer front lower ball joints oem
Front lower control arm #2 polyurethane bushings figs
Real carbon fiber rear strut bar
Rear eibach sway bars
Upgraded sway bar end links and bushings from figs
Rear Mega lower control arms for more strength and adjustments for lowered vehicles, figs.
Rear toe links for more adjustments for lowered vehicles, figs
Rear spherical knuckle bearings figs replaced the old oem ones
Enkei lightweight wheels I believe rs7 can't remember the model name, very nice and unique look
Short stubby aftermarket JDM antenna
Newer spark plug wires and spark plugs
Replaced vvti pulley oem
Replaced harmonic balancer oem
Did all timing belt water pump thermostat radiator and hoses not too long ago, all oem
Replaced pcv valve
Replaced ocv valve and filter oem
Cleaned maf sensor correctly
Aftermarket drop in air intake filter, can be washed and dried infinite number of times to clean
Joe z air intake tube. Also have original oem one
Replaced fluid for transmission, differential, brakes not too long ago
Always oil and filter change on time, full synthetic extended performance Mobil 1 with matching extended performance filter.
Interior is like new, no melting of the dashboard like other year models. Super clean seats etc
Aftermarket radio head unit mp3 player Android big screen, capable of backup camera
4 new tires Michelin pilot sport as3+
There's probably more but too much to list.
The cons:
Slight crack to front passenger bumper, nothing serious, bumped into a friend's car at parking lot speeds
Front passenger headlight is out, not fully but needs replacing, still functions
Minor wear and tear, but the paint is very nice for the age of the car
Buy this great car from a good responsible seller.
These cars are getting harder to find in good condition.
I've spent a lot of money on this car and made sure to do it right
Text 858-776-9359
1 - 2 of 2 Posts
About this Discussion
1 Reply
2 Participants
austinaltezz
Lexus IS Forum
Full Forum Listing
