2002 Lexus IS300
Based on the two wiring diagrams you provided, they are exactly the same colors with the exception of one ground wire on the 2002+ which is White/black tracer wire whereas the 2001 ground wire is White/green tracer.
Hmm I must have a different year model, afaik, there are different coloured lines that run down the wire as opposed to the 2001
2002 Lexus IS300
Well if you look at both the 2001 and 2002+ diagrams, you will see they both match aside from one ground wire.
