Ouch Fuckford Rusgate, Hope you don't like clean audio. Check the THD levels.Montreal said:Two 12" JL With A 2000 watt rockford amp stock head unit. I also ordered a 7" lcd screen for my Lint tray and a alpine dvd/vcd player for the glove!
Thanks
What? sure Rockford fosgate makes Killer products, uless you wanna spend a couple grand on an amp they are the best IMO, I rate Diamond audio the "best" but you could boost your car for the same amount as a diamond audio systemFig said:Ouch Fuckford Rusgate, Hope you don't like clean audio. Check the THD levels.Montreal said:Two 12" JL With A 2000 watt rockford amp stock head unit. I also ordered a 7" lcd screen for my Lint tray and a alpine dvd/vcd player for the glove!
Thanks
You need to see what impedance your amp is stable to and buy the speakers that will give you a matched impedance for max output.
If your amp can handle 1 ohm mono, buy two 2 ohm sepakers and wire them in parallel.
Fig
W7's? The latest Power series Rockford amps? Unless you need to run it a 1 or 2 ohms to get it to put out 2000 watts, just get 4 ohms and call it a day.Montreal said:Two 12" JL With A 2000 watt rockford amp stock head unit. I also ordered a 7" lcd screen for my Lint tray and a alpine dvd/vcd player for the glove!
Thanks
Man, I installed competition audio for 7 years and all I am saying is that the clarity of the amplifiers is very poor. typical THD levels are .1% where most quality amplifiers I think should have at least .01% or .001%. Granted the amps are measured at 100KHZ and for a bass amp your typical freq range is 20-120HZ so it may not matter too much.low430 said:What? sure Rockford fosgate makes Killer products, uless you wanna spend a couple grand on an amp they are the best IMO, I rate Diamond audio the "best" but you could boost your car for the same amount as a diamond audio systemFig said:Ouch Fuckford Rusgate, Hope you don't like clean audio. Check the THD levels.Montreal said:Two 12" JL With A 2000 watt rockford amp stock head unit. I also ordered a 7" lcd screen for my Lint tray and a alpine dvd/vcd player for the glove!
Thanks
Fig
No fucking way it is RMS, if so, I just don't understand it. Then again, Rockford rates all their stuff RMS, but I think they are doing it now at the lowest impedance. Shady IMHO. Without the model number, it's all a guess.Fig said:Man, I installed competition audio for 7 years and all I am saying is that the clarity of the amplifiers is very poor. typical THD levels are .1% where most quality amplifiers I think should have at least .01% or .001%. Granted the amps are measured at 100KHZ and for a bass amp your typical freq range is 20-120HZ so it may not matter too much.low430 said:What? sure Rockford fosgate makes Killer products, uless you wanna spend a couple grand on an amp they are the best IMO, I rate Diamond audio the "best" but you could boost your car for the same amount as a diamond audio systemFig said:Ouch Fuckford Rusgate, Hope you don't like clean audio. Check the THD levels.Montreal said:Two 12" JL With A 2000 watt rockford amp stock head unit. I also ordered a 7" lcd screen for my Lint tray and a alpine dvd/vcd player for the glove!
Thanks
Fig
In general I think the RF power sounds "sloppy". But there are few out there that value sound quality over quantity. :roll:
Is 2000 watts the peak, RMS or WLS (when lightning strikes) rating??
And how are you going to supply the amp 2000 watts of power off your electrical system.
2000W/14V = 142A. I hope you have about 4 batteries and and aux. alternator just for the stereo :lol:
___end 2 cents here___
Fig
