Okay so about a week and a half ago, I had replaced the engine harness, due to an engine fire, and while I was replacing the harness with everything already taken off, I had replaced the valve cover gaskets, the spark plugs, coil packs, spark plug wires, fuel injectors, and also cleaned the throttle body and the intake manifold (plenums).
After putting everything back together, I figured I’d have a bunch of codes, but I didn’t, it was running a bit rough, but I figured brand new injectors along with plugs and all, it’s probably just out of wack. So I let it idle to temp, took it for a drive, and it didn’t feel right, it took a bit of throttle to go, but I figured out I had my throttle cable set backwards (not enough tension) so I fixed that, but I still have a small choking/bogging (rpm drops a lot) acts like it’s going to die, but then will start to go, and drives fine after that. Sometimes I will get a pending CEL code when I start my car, but it rarely actually pops on my dash, it’s for a too rich in bank 1 and 2. Unsure if I should put my old injectors or if it’s just the computer needing to adjust still.
Also the other issue I’m now having (keep in mind I drive with trac off, is when I come to a stop, my trac light and abs light with flash together, and then when I accelerate the trac light stays on like it should and the abs light turns off. My car sat for about a month to a month a half with the wheels off and garbage bags over the rotors (I live in a rainy place) any ideas?
I seen some forums say my wheel speed sensor, but I also remember someone mentioning that they don’t really go out too often, they just get dirty. Could it be a wheel sensor? Or could it be something else?
