1 - 1 of 1 Posts
I recently replaced all 3 belts in my Lexus IS200. In the midst of the replacement I broke the bolt that raises the alternator and tightens the belt around it. Now the belt is stretched out and is making a lot of noises in the engine. The issue is I've tried to find this bolt to replace it but I can't find the size of the two bolts needed to tighten this!
I know they are both 8mm x ?.
The two bolts I need are approx. the 8mm x 120 mm and the 8mm x 20 mm bolt that the long bolt pushes on the tighten. I'll add a picture later once I get back home. If someone has an IS200 and can provide a picture of the bolts I'm talking about so I can get a better look.
Hope this makes sense.
1 - 1 of 1 Posts
