1 - 9 of 9 Posts
Sofa King
anybody running 18x8.5 +41, or something close with a 235 tire in the front? i need to see pics
not likely.
I have 18x8.5 +45 with a 225 tire and have no room on the inside, and basically nothing on the outside. or I'll rub, especially on bumps.
These sizes will cause your vehicle to explode.
thanks for the helpful advice illricer...:pissed:
+41's on a 8.5" are low? :lol:
Some people just realize what it will take to fit certain rims while being as low as they want. Camber adjustment clearance dictates width and offset for some.
Sure, I could run some 245's on 10.5" rears with a +40mm offset if I shave and slightly pull the fenders with excessive negative camber. Kinda pointless since a lighter 8.5" or 9" rear could utilize the same contact patch area without sacrificing my desired height and camber settings due to my power levels/goals.
To each his own I suppose.
1 - 9 of 9 Posts
