ok i did some calculation the front calculation is 63mm and the rear is 75mm
the fender limit stated on the thread Front: 65mm Rears: 75mm and am planning to run those tires. am thinking rolled flat then a little pull to make this happen? input would be great. thanks!
i would go 255/35 in the back and 225/40 up front this would keep your wheel/tire height very similar right around 21.5inches, if you try and go that wide up front you will have to do fender work and on top of that probably need spacers depending on the offset, that just sounds like even more fender work after you add the spacers!
i def respect the ambition, but in this case it may be more work than your wanting?
remember to add in your negative camber from any drop you have as well, that can help with clearance on the fenders as well.
