1 - 8 of 8 Posts
I have an 03 IS dropped with tein springs and tokico socks. The droped is a 1.3 in the front and 1.6 in the back. I want to run 18's on the way around. What size can I run without bending the fenders and not rubbing in the front?
can you post some pics??
I've got on 03, and i'm dropped about the same amount if not a tiny bit more than you and im running 18x8's with a 43 offset all around. So you have plenty of options... Good luck with your search...
I'm dropped on an Eibach pro kit which lowers about 1" and I am running 18's. It looks to me like there would be room for your drop to work fine with some 18's without rubbing.
I rolled around for 2 years on 18x7.5" +48 and had no issues. I'm dropped on H&R's which is about 1.5" all around. Just use a 215 or 225 series tire and you'll be fine....
1 - 8 of 8 Posts
