has anyone done this? any issues if i were to do this?
i was looking into 18/8.5 front with a 235/35/18 up too 255*
and a 19/9.5 rear with a 255/30/19 tire up too 275*
what offset would i need? do i need to roll fenders or get flairs if i lower 1.5"?
will abs work still?
* not sure what size yet depends on what i do to the motor...
thanks in advance :)
Reactions: destron25
I would not mix the sizes with the wheels, you can/will throw off your wheel speed sensor and can/will affect your abs. IMO just go with 19's staggered. I ran with 19x8.5 225/35/19 front and 19x9.5 255/30/19 with no problems.
sweet thanks for the info man! that was what i was going to do if the 18/19 setup didnt work out.
id like to see some pics if anyones done this ive seen them on lambos before and they look sick but idk how theyd look on an is
i think that is how most m3's are set up and i know most z06 vettes have 20's rear and 19's front
the HKS altezza is running 18s in the front and 19s in the back.
Be it true, but those cars were designed that way from the factory. All handling, weight, braking/ABS, traction control etc... were all adjusted and accounted for. In my opinion its not the safest way to go and not really beneficial anyways. Just my 2 cents.
