Hi all,
I have scoured some of the threads, but haven't been able to determine if this setup will work:
  • RPF1 17x8.5 +30 245/40R17
  • Slight drop with coilovers
From what I have gathered, I just need to do some minor fender rolling, but that should be it. Can any gurus confirm?
use fitment industries in the gallery section. they have pictures and confirmed info THERE for you....
Hi all,
Hi, I am running 17x9 +35 245/40R17 also all around. Car is lowered about 2" from stock and have minor fender rolling. FRONT: No rubbing except inside front tire on inside of my fenderwell at absolute full lock. REAR: No rubbing during normal driving but if suspension totally bottoms out / near 100% compression it will rub slightly on fender. I don't have any negative camber though (couple degrees would probably help).
If you are on an 8.5" wheel with +30 it's within 2 mm of my setup on the outside so you should be good.
Thank you for the information. I'm wondering how much that 2 mm will make a difference. I haven't had the fenders rolled yet, but it sounds like I'll need to push out as much as I can to fit this setup.
