will they fit?
with what offset?
tried search
with what offset?
tried search
do you want the 17's for weight? if so i gues its for racing, and if this is the case, you will further excentuate the understeering characteristic of the car with that stagger. only thought, should look mean otherwiseaaronyoung said:gosh that is a high offset. I was thinking something in the 38 range.
Thanks for the info though
I am looking to go 17x9 in the rear with a 245 or 255 /40
and 17x8 in the front with a 215 or 225
I don't mind rolling the quarters/fenders at all.
hey BD-rich, for reals an 18x10 rim + tire will fit in our rear. So i imagine a tire that is 275ish then right?BigDaddyRich said:17x9 45mm-51mm will fit nicely
Keep in mind different wheel manufacturers have their own ideas as to offset.
I have had 18x8 wheels with a 52mm offset fit in the rear just as nicely as a 18x9 with a 45mm. I also had a 17x7 with a 43mm fit nice too.
I know of a 18x10 with a 45mm that fits with a rolled fender.
So anything between 44-50mm will be ok
yes it is a track car.somguy2u said:do you want the 17's for weight? if so i gues its for racing, and if this is the case, you will further excentuate the understeering characteristic of the car with that stagger. only thought, should look mean otherwiseaaronyoung said:gosh that is a high offset. I was thinking something in the 38 range.
I just got a set of 17x8 SSR Competitions. I'm putting 245/45/17 Falken Azenis on them. They should just BARELY fit up front.aaronyoung said:yes it is a track car.
475whp with 475ft/lbs of torque will keep the rear wheels pretty busy.
I want the 17's because they are cheaper to replace, and tire cost is a little bit lower.
Of course! The good news is the 17" SSR Comps fit over the Rotora BBK with room to spare.aaronyoung said:by all means let us know if they fit![]()
I dunno man here's a pic of my friend Charles (isman) setup thats a 18x10/45mm with a 265. he's going wider tire soon I was told, he just wearing these out first.goldznnz said:hey BD-rich, for reals an 18x10 rim + tire will fit in our rear. So i imagine a tire that is 275ish then right?BigDaddyRich said:17x9 45mm-51mm will fit nicely
and do you know how extreme the roll would be in the rear?
do you think a SSR rim thats 18x10 would work bro?
thanks
Hey Rich, i spoke to Charles about the rims and he said the 10s in back rub quite a bit. He has plans for fender flares soon so he's keeping the rims. I think if you dont want to go with flares then stay away from the 18x10.BigDaddyRich said:I dunno man here's a pic of my friend Charles (isman) setup thats a 18x10/45mm with a 265. he's going wider tire soon I was told, he just wearing these out first.goldznnz said:hey BD-rich, for reals an 18x10 rim + tire will fit in our rear. So i imagine a tire that is 275ish then right?BigDaddyRich said:17x9 45mm-51mm will fit nicely
thanks
Whew, I didn't even think that'd be an issue. Guess I was lucky. They are +38 offset.Dave said:what offset do you have in the ssr comps to make the 245's clear the steering knuckle?
Also, have you noticed any loss in acceleration with the taller tire? I think my 235/40's accelerate better than my 225/45 azenis, but who knows, it could all be in my head.
Thanks for the update.
its the lighting bro, that car is ridiculously cleandut said:- damn, the front lip looks fuccked... could be the lighting though...![]()
