541 - 557 of 557 Posts
Can we start adding the HP that each car makes to give everyone a general idea?
^very nice, what tire size?
its a 255/35/18 Federal 595SS. Its only like an $80 tire. But that Racelogic Traction control is just sick. Just slip the clutch a little bit and it goes. I think that if I had a better tire, like a Toyo R888 or something that hooks, I think it could of pulled a 1.8 flat no problem.
My best time before I blew up my engine last weekend. 11.55 at 120mph with a 1.68 60 foot.
Running Mickey Thompson ET Streets
Finally got it together to go back to the track. This was at Sydney Dragway in Australia.
The car is an IS200 with 2jzgte conversion. tremec 6 speed. SP67BB turbo on e85.
[email protected] mph
CONGRATS! :approve:
Video? pics of engine?
What kind of hp/tq were you making on this pass?
That is one fast Lex! Which tremec transmission are you using and did you swap the diff? I've been entertaining that option for a while now and would love to know more.
There is no conventional air-air intercooler in the car. It has a water to air intercooler, what you are looking at is the actual bumper that got fiber glass molded to cover the big hole in the front of the bumper.
Sorry Guys - I didn't get notification of all the attention my post got here.
The transmission is a tremec TR6060 6 speed. Diff is a toyota g series (Standard is300 size?) with micro polished 4.086:1 gears.
The engine at that time dyno'd at around 460 rwkw, more recently it has done a best of 493rwkw (~660rwhp), always on Mainline chassis dyno's. We added a little more boost (28psi) and leaned on it a bit.
Did it take a lot of custom work to fit that transmission?
I guess it did.
We measured up, drew for CNC and had a small run of 5 adapter plates machined out of billet.
The plate joins the gearbox case to a Toyota J1 auto bell housing from a 1jzgte soarer.
The clutch plates were resplined to suit 26 spine chev pattern. There is a pretty rare sized thrust bearing on the spigot.
The shifter is a modified aftermarket unit from a GT500 mustang.
Custom Gbox mount / shaft adapter / tailshaft.
3/4inch willwood remote reservoir master cylinder.
We used an aftermarket billet concentric slave cylinder as the factory ones are known to fail.
NO tunnel mods !! yay - lol I think that was the only thing we didn't have to make from scratch.
I guess it did.
very impressive! you must be the first one running that setup
It took a lot of sorting out. In the end Im not sure I would have gone the same route.
That said it is a great thing to drive now. The ratios are spot on and the box feels indestructible.
