1 - 10 of 10 Posts
i want to know is it possible to put 10inch in the rear. i am looking at some advan rims and they dont come in 9.5. the offset is a 45, so does any one have any ideas on how this can work. what would be the right tire size for this.
thanks
You will have to cut out the inner fender and then pull the quater panel out to have clearance. I have 19 9.5 in the rear running 265 30 19 and i rub every where.
are you going with a 10" width just for looks or are you planning on an enormous amount of hp in the future
the +45 offset will be too low for the rear, try to find something like a +55 offset, even then, you will most likely still have to modify your fender
you can run 265/275 in the rear or even 285 with some modification to your fender
pretty much with whatever offset or tire size you get, you will probably have to modify your fender
czar - what's the offset on your wheels
It's possible to fit 10" rims in the rear but it's not worth it if you're not producing a shitload of power. It seems like the maximum rear width you can use without doing some serious fender work is 9.5" (+55). If you're going to put on 10" rims, you're going to need to get your fenders pulled. You might want to ask John (Lexus_IS300) on what he did to fit his 10" Blitzs.
thats funny im running a +45 in the rear with a 265/30 tire
yeah but he has flares so that helps too..I have 285/25/18's with a 10inch rim it rubs alil I dont mind anymore..
I dont quite know, i got a set for a supra and shaved the wheel 5mm. Thats the only way i got a set of C4s to fit.
1 - 10 of 10 Posts
