1 - 20 of 24 Posts
Podiatrist
I had this engine cover made for me way way back.
I designed it myself and had it prototyped it with a sheet metal fabrication ship.
total cost with the sheet metal shop was about $700
I GUARANTEE there is no other engine cover like this...unless someone stole the design.
It is made in brushed stainless steel. Very sturdy. 1/8" thick I believe.
There are some slight scuffs on it from sitting around for so long...but since it's a brushed metal, it's pretty hard to tell.
Selling it for $175shipped. (price drop)
You will need to finger out the mounting. Should be as simple as getting some different length studs and cutting some angles in rods. Then secure with a nut just like stock.
de, so this is considerably thinner than the stock one? i have a strut bar and don't want it to rub............also from the picture it looks as though it might scrape that painted cover........mines painted as well so i don't want it scraping the paint - can you take a better pic of its clearance? thanks
because it's constructed out of stainless steel wouldn't it tend to hold in heat and deflect the heat back down towards the motor and intake???
Podiatrist
The clearance depends on how you decide to mount it. You finger out the mounting screws and clearance on your own. I never had a STB so I dunno bout clearance.
I believe you have it backwards. Metal is a conductor of heat. Plastic is an insulator.
This would act like a heat sink rather than a blanket.
The engine cover would heat up a lot...this dissipates heat, not trapping it.
Looks dope. I am curious if your temp went up though? Have you driven with it for a while to see what happends?
Podiatrist
Discussion Starter #8
Temp would go down, not up.
I never had this on the car.
And I wouldn't know even if I did. My hood is vented and there's a turbo sitting there that produces more heat than the engine used to.
Would this fit with the larger turbo intake piping? Stock one doesn't, right?
Podiatrist
Discussion Starter #11
I think the stock one does. The pipe that goes the throttle body isn't larger...I think SRT uses a reducer.
Podiatrist
Discussion Starter #14
well..make an offer. It's hard to really list a price on something like this.
Podiatrist
Discussion Starter #15
Ok $150 shipped
keeping in mind this cost me over $700 to make.
Podiatrist
Discussion Starter #16
speed bump. make an offer
Podiatrist
Discussion Starter #18
Cause I'm boosted and don't give a shit about the engine cover anymore.
It's been sittin around fer years.
Podiatrist
Discussion Starter #19
Price drop to 175 shipped.
Rollin Boosted
SophieSleeps said:
Ok $150 shipped
^^How can the price drop to 175 from 150? -B
1 - 20 of 24 Posts
