1 - 10 of 10 Posts
my car is Is250 2007.
when i drive my car, it makes cracking noise behind audio very randomly.
is there any ways to fix that?
Look at the ST indicator, if its fading and going on and off you are losing signal. Mine is noisy, ie crackling, when it does that, and in the rain its worse as signal is worse.
I get the same random noise in my 06 IS250. No navi as well. It's more of a random one off creaking / cracking noise and will appear once in a while out of no where.
There is a TSB for this...its the front dash clips that are loose causing the noise. Is it coming from behind the radio, as if wires are loose or something, and then pop and cracks as you go over bumps? If so, it is covered under warranty and TSB. Something about revised dash clips....stupid Toyota and their cost-cutting shenanigans. Also, just as a heads up, if it is the dashboard TSB, you better make sure your dealer has done this before...as the wrong tech can seriously scuff up your interior. Good luck!
1 - 10 of 10 Posts
