Just wondering how long it takes for orders to be sent out from this site. I ordered the '04 Dash Tray about two weeks ago and was curious if I will be waiting until enough are ordered so that a group order can be put in.
Also the order showed up on my credit card bill as being paid to "Man and Machine LTD" in Davie Florida. Is that correct??
You paid the correct place!!! :chill:
Not sure how long it normally takes for an order to be processed.
SEMA might have something to do with them being slow.
yikes
....just saw this post on Lexusownersclub.com regarding the OEM dash tray:
"I can get hold of the new OEM version, but it will be significantly more expensive :(
However, that is not the worst part, that is that Lexus changed the entire top part for the so-called 2004 model :( :(
You need to replace many parts (basically you need to upgrade the midconsole top, like the vents, ....)
So, not recommended."
Please tell me this is not accurate!!!!
From what has been discussed before,
you change the whole top tray.
The little air-flow things need to be removed and installed into the new tray.
The procedure is extremely simple. A child can get it done.
